That sounds similar to the video posted..sometimes ill cut a small slit on the bottom and in the middle of that slit go vertically a bit. cut a hole in the top of the seal so it doesnt glug
sometime tonight ill post a pic
different method with the same result, so pretty muchThat sounds similar to the video posted..
Welcome brother, you should spend more time here you'll fit right in! It's a BITOG thing.Just wondering what the best way is to prevent a chunk of the plastic jug seal from contaminating the oil. Ive always punched it in, or tried to peal if off, but it never comes off cleanly.
Thanks!
Thanks bud.. I'm all over the place asking questions bc I have a trust issue and try to do everything myself.Welcome brother, you should spend more time here you'll fit right in! It's a BITOG thing.
I cut around the edge in a circle with a sharp utility knife and grab it as soon as I can and just lift the little disc out.
For the Supertech jugs I would use an Exacto knife and cut 90% of the perimeter where the seal meets the jug and then pop it off there. That stuff is so stretchy you need a crazy sharp implement.
Marshmallow paste. Not kidding. I had the same problem and searched the web. Coons have a sweet tooth and cats don't seem to want marshmallowsThanks bud.. I'm all over the place asking questions bc I have a trust issue and try to do everything myself.
Know how to trap a big coon without trapping a cat? Kid "borrowed" my rifle and wont give it back.
I hope you don't perform any medical surgery.
Again, looks to be a ST jug and they use an odd white (I think?) cover with a weird cling-wrap-esque coating underneath. Even the sharpest knife won't cut cling wrap very well. It's not exactly cling wrap, either, as it seems more stretchy and rubbery, but almost thinner. I dunno -- words can't easily explain it.I hope you don't perform any medical surgery.
Sorry to say but my 6 year old grandson would do better, yikes!
Exactly what I do.I poke it with a screwdriver, stick my finger in the hole, and tear as much off as will come off. I don't worry about the rest.
