safe plan for subaru 2.5L?
ohio
Hi all, recent registree long time reader. Id like to extend my oil drain time so heres the plan I 'came up with'. Synthetic Oil (usually mobil 1 5w30, I recently put in Valvoline Syntec 5w30) change filter at 3100 miles (add oil as necessary, I figure about 1 qrtr) change oil & filter at 7200 miles.
Pretty conservative. Shouldn't be a problem. As usual do a UOA . If you have a coolant leak 7K miles is a long time.
coolant leaks are especially harsh on oil? man i dont wanna do a uoa! the whole point is to save money, while being conservative. Doing a uoa voids the save money portion [Smile] edit: i watch my cocolant very carefully, and dont lose more than 1 cm from the resevoir tank every 3 months.
Hes talking about when coolant is leaking into the engine. If you have a real slow internal leak you may not notice and the oil and coolant will have a party GM 60 degree v6 owners know all too much about. If you have a coolant leak you should know it because your coolant will be disappearing, or it will be leaking onto the ground. I think you will be absolutely fine with your plan, no need to do UOAs, but with them you could extend the interval farther, find problems before they happen, and its fun.
What's up jejunum! Seen you over on nasioc. I have a thread you might be interested in on this page, about my 2.5l... [Smile]
quote:
Originally posted by Jejunum: Hi all, recent registree long time reader. Id like to extend my oil drain time so heres the plan I 'came up with'. Synthetic Oil (usually mobil 1 5w30, I recently put in Valvoline Syntec 5w30) change filter at 3100 miles (add oil as necessary, I figure about 1 qrtr) change oil & filter at 7200 miles.
why'd you change from Mobil 1? Mobil 1 is superior to valvoline. 3,000-5,000 miles sounds right for an OCI.
quote:
changed from mobil 1 beacuse...the valvoline snytec was free after rebate ) "What's up jejunum! Seen you over on nasioc. I have a thread you might be interested in on this page, about my 2.5l... [Smile] yah i did see your thread thanks alot!
