Originally Posted By: bunnspecial
Originally Posted By: FordCapriDriver
As Shannow said before 1959 BMC A-Series engines all were spec'd for simply SAE 30, then 20W-50 became the "universal" oil for them, shared sump or not.
So SAE 30 or 40 would be fine for a couple months.
I wuld probably run something like Shell Rotella T4/T5 15W-40 or Valvoline Vr1 20W-50 for the long term in it
, A- Series engines tend to leak oil no matter what and they purr really happy on a good HDEO or 20W-50 PCMO.
B engine, not A...although they're more alike than different. The A just looks like a 3/4 scale model of a B
(and a 1275 A engine doesn't have removable tappet galley covers, which eliminates on common source of oil leaks but also means a full tear-down if you want to change tappets or even inadvertently lfit one...)
With that said, the rear oil seal on the B engine is a different design from that on the A. B engine only leak there if the seal is bad, while A engine basically can't be stopped from leaking.
My main oil loss now is through the PCV system, which tells me that the rings are shot. At one point, I made a catch can out of a 1L side arm flask packed with glass wool. In an hour on the interstate, I'd collect ~100ml of oil.
BTW, I have a big stash of VR-1 20W-50, but I don't want to dip into it for this OCI. This is basically out of necessity of "I need to change the oil after the head gasket job but want to save the good oil for when the engine is actually healthy again."
Aha, understood.
