Saab Red Coolant Options?
JHZR2
Staff member
New Jersey
Yeah what year? Saab used G-48 blue then went to the Glysantin version of dex cool.
ET16
MD
The car is a 2005 9-5. It has the red coolant in it now. I bought a liter of Pentosin red coolant today. I'll use that, but if I can use a Dexcool clone, I'd like to use that in the future.
J_R
Oakland, CA
Is the Pentosin red compatible with Dex Cool? If it were my car I'd just use Dex Cool, I am no coolant expert though..
Seattle-ish, WA
Pentosin Red (Pentofrost A1) is for Toyota and Lexus, other asians. It might be ok in your system if it was thoroughly flushed with water from the original coolant and the existing one is in fact the 'Asian' red. You should probably find out what is in it for certain. I think yours came with Dexcool, and orange or orange-red. Verify the color and don't change add the Pentosin until you know (assuming it is Pentofrost A1 - only red Pentosin I know). If you added A1 to Dexcool it will likely need to be fully flushed at least twice with distilled water and new coolant introduced.
The Old North State
Your Saab would not spec Pentosin "red" (Asian formula) as the link below confirms. It would spec Pentofrost SF which is pink(ish) in color. Based on the spec sheet it would appear to be a DexCool formula as noted above. Wondering if you are saying red but meaning pink(ish.) Suppose you could use Pentofrost Red with a complete flush, but as it specs pink SF that would be my first choice. http://www.pentosin.net/f_antifreeze.asp
Champlain/Hudson Valley
Hello, We have 2 "GM Saabs" in the family-soon to be 3. They take Dex-Cool. Do the rinse. Get it to clear. We'll have 2 2002 9-5's and a 2005 9-5 Aero. All have the 4 cyl. engine. The 1999 9-5SE had G-46 (familiar dark blue coolant) but I converted that to G-05. Everybody's happy. Kira
ET16
MD
Sorry, I thought my pink fluid was "red". I see that it is "pink". I bought the Pentosin that is also good for Mercedes.
