I thought the batteries were lifetime but on the Home Depot website seems to indicate everything manufactured after 2011 is 3 years. So what gives? Is my memory faulty at 68 yr old?
Yes I believe 3-yr warranty is right. I just registered new tools and batteries on the ryobi site.I thought the batteries were lifetime but on the Home Depot website seems to indicate everything manufactured after 2011 is 3 years. So what gives? Is my memory faulty at 68 yr old?
This! However, it only applies to the batteries packaged with the tools. If you buy the nice up-sized battery itself, it’s not lifetime. Rigid and ryobi and produced by the same parent company, curiously enough.I believe the lifetime warranty on batteries is on their Ridgid tools, if they are properly registered, and the consumer goes through all the multiple gyrations required to complete such task.
Is there some kind of control module inside? Maybe beyond overheat protection, like a timer, or some communication channel with the charger. Would be interesting to see if an knockoff aftermarket charger keeps them going.Their batteries 100% have some built in obsolescence. I bought a cheap weed whacker/blower 18v combo years ago. Every spring it says the battery is bad. I take it apart and charge the cells in them one pair at a time with a variable power supply to about 4.1v, takes me about a full day swapping to the next set of cells every few hours. Once I do this and start using it, it works flawlessly all summer long.
I'll have to do some looking into this. As a contractor, we lose a lot of tools to stupidity, theft and whatever, so I had looked into Rigid tools, and found at the time, that you could register individual batteries, but that may have changed in the mean time.This! However, it only applies to the batteries packaged with the tools. If you buy the nice up-sized battery itself, it’s not lifetime. Rigid and ryobi and produced by the same parent company, curiously enough.
