About 2 years ago I bought a very high quality 2200 Watt inverter that is made by Mean Well.
This is a big step up in relialibality from most inverters out there that may or may not work, and may or may not provide a clean sine-wave that can run anything. Some electronics and electrical items may not work if powered by an inverter that does not have a very clean sine wave. Some items can even be irreversible damaged.
Mean Well inverters make as clean as or even cleaner, sine-wave as you will get from a utility company. These are inverters that are used in expensive yacht, these are very clean sine-wave output inverters. And their reliability is medical grade.
The down-side is that they ain't cheap. Aug 1, 2022 I paid 814.03 + 15.19 shipping, + 58.05 tax = total of 887.27 for one.
Keep in mind that all inverters have the maximum power they can produce derated as the ambient temperature increases. So that alone is a good reason to buy something with extra capacity.
Here is an example of the derating for my Mean Well NTS - 2200:
-13F to 104F 2200W
122F 1760W
140F 1100W
158F 800W
input voltage
10vdc 1760 W ramps up to 2200 W @ 10.5 vdc
10.5 to 16.5 vdc 2200 W
these Mean Well inverters have a lot of built in protection to prevent accidental damage.
Generally inverters are designed to hand only one of several input voltages.
12VDC, 24VDC, 48VDC
My 2200 W 12vdc in is wired with 0 GA. Stranded pure copper for the 12 vdc input. And that ain't cheap.
I had a vehicle stereo shop do the 0 GA. wiring. They had the wire and hydraulic crimper. I had bought a 350 A / 185 A at idle alternator from APEX, and I put in a larger battery. On youtube look up "the big 3 upgrade". Wire to the back seat for the inverter, quick connect, fuse, better battery connections, install and wire the upgrade alternator, cost me $1,000.00 at the stereo shop. Copper is expensive, and that is why people use 24vdc or 48 vdc when they can because they can use thinner less expensive copper wire.
Avoid like the plague aluminum and aluminum with copper clad wire.
Mean Well makes them in 300 W, 450 W, 750 W, 1200 W, 1700 W, 2200 W, 3200 W
and they make them in 12, 24, 48 vdc in
the output is adjustable by user to any one of 100, 110, 115, 120 vac
They also make 200, 220, 230, 240 vac units
And they make units that can be used as a ups but that is an additional design and more expensive.
they also make some battery chargers, maintainers, and other supplies
Higher voltages allow you to use thinner less expensive wire. But the dangers of death from electric shock increase as voltage increases.
These are very high quality inverters and very reliable, and just about impossible to accidently electrically damage. And very expexsive.
You pays your money, and you makes your choice.
BTW, the one I got has two fans that it automatically varies the speed of to minimize power used, but maintain proper cooling when required.
Sometimes it better to cry once in the beginning about the price, and know you have something that is rock solid medical grade reliable, than put up with the hassle of something that breaks when you need it leaving you something that does not work and has to be thrown away, and you having to buy something better later.
What ever you get, be sure it has plenty of cooling ventilation and keep the air filters clean. Heat and dirt kill even good equipment.
When I bought mine, I had to call Mean Well and find out from them which of their electrical distributors has the one I wanted in stock. I bought from Mouser.
