Hyundai had issues with water pump impellers rusting away. Seems cavitation is most likely to occur there and a likely cause
A very real possibility
I worked at Ford and as far as all the techs said it was indeed electrolysis. They needed very frequent coolant flushed to keep them from turning black.When I purchased my 91 Taurus 3.0 Vulcan, it needed a radiator so I changed it and put a new water pump and hoses on it. The system has lots of rust in it. I got alot out but 2 years later, it's full of rust again. I never known a 3.0L Vulcan that didn't have rust. Is there a better than average flush for getting the rust out? Or additive to keep it from rusting further? I remember my shop teacher saying it was because of electrolysis. How do you fix that though?
That is only partially true, I mean if the thing is rotted to Hades inside it may lead to gasket issues especially if it uses a shim stock HG (I dont believe yours does) and not a multi layered one but over the years I have seen lots of rusty cooling systems, you could say it was more common than not with engines that that had used alcohol antifreeze.
You may need to do a couple of cleanings with the citric acid but with the thermostat out and removing the lower hose and heater hoses to flush fresh water through you can get it clean. A thorough flushing is mandatory if you want it all out.
I had the same issue a few years after installing my 76 Oldsmobile 350 in my car. It had been sitting a long time and had rust, leaking freeze plugs. It started to run hot on the highway and coolant was very dirty looking after 3 years so I did a major flush with the machine at work, just water until it was clean, and put in modern multi vehicle coolant. It lasted a good few more years before looking dirty again and I flushed it again, so the rust seems to be under control in my case.@Trav
one mechanic told me once the rust has started and you have rusty color coolant you are done and cleaning won't help and just delaying the inevitable
Is that true?
it was many years ago and I was talking to him about purchasing an old car and he was saying take that into consideration. In this case the coolant was all rusty color with no green.
CLR, which actually is a variety pack of different weak acids
My evaporator also has a leak so heater core will be replaced also.The Taurus was plagued for years with heater cores that would fail. My guess is maybe yours is going too.
Probably not the 2 degrees but the better quality thermostat and or cleaning all the garbage out. I recall us having to flush a 3.0 Sable 3 times over a period of a couple months to keep the heater core from plugging up. I can't remember if we ended up having to replace it, but it wasn't leaking, just had no heat and very black coolant.Well I did the flush today. I used the citric acid and loads of rust and scale cane out. Water was almost black. I installed the correct motorcraft 197°f thermostate and guage now stays on the middle instead of bouncing around like it did before with a after market 195°f. Who knew 2°f would make that much difference.
Agree. Motorad was the aftermarket brand.Probably not the 2 degrees but the better quality thermostat and or cleaning all the garbage out. I recall us having to flush a 3.0 Sable 3 times over a period of a couple months to keep the heater core from plugging up. I can't remember if we ended up having to replace it, but it wasn't leaking, just had no heat and very black coolant.
