Rumble in suspension- 2001 Civic
stl
I've got a rumble in what I believe to be the front suspension on my '01 Civic. It's like a rumble sound, that I can only hear on bumpy roads, like a gravel road, sharp bumps, not highway type bumps.
Awhile back I replaced the front control arm front compliance bushings. They were very worn, but this did not fix the problem. The rear bushings seemed like new still, so I left them.
I then assumed it was the front struts, they're the original units with 245k miles on them, so I replaced them with a complete quick strut assembly. But I still hear the rumbling. Ride doesn't seem any better either,
I've tried to find any play in the ball joints, and tie rods, but they all seem okay to me.
I'm at a loss, any suggestions?
I just went over things again.
How much up and down movement is allowed in a drive axle?
Car on stands, no weight on wheels.
The one thing I noticed at my shop is that when we order new struts for a customer it never comes with the "extras" you think it would. So all of the "old" things like stop bumps and hardware are reused.
So a worn out rubber bushing reinstalled on the new strut may also be a point of the suspension making noise. Also the swaybar end links make a lot of noise as well when worn.
I'm starting to think it's the cv joints. The boots are not torn, but when I grab them near the transmission, and shack up and down, there is a audible clunking sound.
Is that abnormal?
By CV joint, do you mean movement between the shaft and the cup? Thats bad I think. The splined shaft that goes into the transmission can have a little movement, something like 1/16" or less? I think last time I gave those a wiggle on my car, they did move a bit more than I thought they would, but they do just slip in. I can't remember if mine clunked or not.
I guess you could look at the motor mounts too, and maybe just a loose part(steering rack?) that resonates with those high frequency bumps.
