Ok, swapped the stat out and it was trashed.
Engine gets up to 95c in 10 minutes now and the heater output is stifling. I think this has been a problem for quite some time.
Here is the thermostat front:
Notice something weird. Notice that the material all around it is missing? Thankfully it is in the rad and not in the block seeing this stat flows to the rad.
Here is the back of the stat and it isn't much better.
As you can see there isnt much of a seal and coolant is being allowed to bypass thus keeping the engine from getting completely up to temperature.
Again, engine is running at 95c steady now and anyone noticing the temp lower than that regardless of temperature should swap in a new one.
[censored], I would check it. The one I just took out will not open anymore even when exposed to boiling water.
BTW, this stat cost me CDN$48 with taxes!!!!! There is no aftermarket up here yet. Sunuvabitch.....
Also, do I have to worry about the missing material?
