RP 5w30 SN KN filter 6200mi zx2
TX
Cu:7ppm
Fe:9ppm
Cr:0ppm
Al:2ppm
Pb:1ppm
Sn:0ppm
Si:12ppm
Na:379ppm
K:1ppm
B:8ppm
Mo:6ppm
Ca:2198ppm
Mg:36ppm
Zn:1004ppm
P:785ppm
ST:0
OXI:16
NIT:11
SUL:47
W:No
A:No
F:No
V100:10.4
Makeup qts:0
This sample was done at Cat. This run had 6200miles and 110 idling hours on it. This is also the same batch of oil that I noticed the light Gray almost graphite feeling varnish on the inside of the plastic valve cover?
My silicon is down from 18ppm to 12ppm, so I think I found my source which was intake boot clamps loose..FIXED.
Car:Escort Zx2 with 223k miles DOHC Zetec 16v motor
Comments..Suggestions?
Dusty
I've covered this before. Sometimes I spend a lot of time in the car and in TExas I want the AC or heat on to be comfortable. PLUS I don't like to start and stop the thing 5-6 times a day If I can help it. Kinda OCD I guess.
I'm the kind of person that
When I see someone shut of and restart a normal car 4-5 times waiting in a drive through..Just let her run' better for the car I'd think
So Rand,
By your estimates the oil has about 9,000 miles on it. The 110 hours of idle times WAS IN ADDITION to the miles driven on the car.
I can't seem to get the pics uploaded. The cam and top of head are absolutely spotless
How do I upload the pics? I'm a noob at this
Upload them to Tinypic,select "message board" as the size,and copy and paste the link here in your post.
Looks like my UOA of RP was better than my UOA of M1.. start calling it M2 cause it's always in SECOND place...hhhhhaaaaahhhaaa
There, that aught to get some posts about UOA
I have started another post do to the lack of comments on the UOA itself
Please don't do that. -MOD
As for the UOA, the engine looks fine overall.
You're wasting expensive lube on such short OCIs. Any decent dino lube could turn in those numbers.
You have a few choices:
1) extend your RP OCIs
2) use dino for these OCIs
3) stay on your current path and continue to waste money
