Royal Purple Syncromax
CA
Thinking of using this in my Focus with the MTX75 manual tranny. I read the old thread on here (searched) regarding the Ford fluid (honey) and the Terry Haines recommendations. What are all you other Focus owners using in your MTX75? I can get the RP for $13/quart locally.
Chicago Area
I have a ZX2, not the same tranny as you. But he Ford honey sauce is reportedly great. Amsoil and Redline make superb tranny oils, as well. I am not a fan of RP anything. I'd use one of the other three I mentioned.
WI
I have an MTX-75 that has had Syncromax in it for years. Works great. Much smoother shifting compared to OEM fluid. I'll be replacing it with the same in the somewhat-near-future. I paid about the same for it, too($13).
NH
I have not used RP SM in your application but if it is compatible with your fluid needs it is an excellent product as are all of their fluids.
The Garden State
I have a 1996 Contour with the 5 sp manual MTX that originally spec'd ATF then in 2000 they spec'd the Ford "Gold" 75W-90 manual tranny fluid. I had the Ford Gold for a while, everything was fine. Went to replace it and several dealers didn't stock it and didn't want to order it unless I bought the entire case. From a Contour site I was a member of Royal Purple Synchromax was recommended as a good alternative. Been using it for several. It shifts just fine. And it has the EP & AW that this tranny needs. Plus I paid mail order $9/qt shipped versus $21/qt at the dealer for the "Gold", it lives up to it's name crzy. Whimsey
Saratoga, NY
Guys, careful about throwing around various names of synchro fluids and assuming they are all comparable/interchangeable. Their viscosity varies greatly: Syncromesh Fluid - Viscosity in cSt ATF type: 6.0 – 7.5 typical Honda MTF II 7.5 Royal Purple Synchromax 7.7 GM/Chrysler Synchromesh type: 8.5-10.0 typical Torco MTF 8.35 Pennzoil Syncromesh: 9.08 Amsoil MTF (5W-30) 9.6 Red Line Oil MTL 10.6 Honda MTF I 10-11? 75W-85 Gear Oils: 12.0-12.5 typical Specialty Formulations MTL-P 12.0-12.5 Castrol Syntorq 75W-85 12.0??? Nissan 75W-85 12.0??? 90 weight Gear oils: 15-16.5 typical Chevron Delo 80W-90 14.2 Royal Purple Max Gear 14.5 (Claimed:21) Amsoil MTG 14.7 Mobil 1 75W-90 15.2 Pennzoil GL4 75W-90 15.3 Red Line Oil MT-90 15.6
USA
Just put Amsoil MTF in my Honda in place of Honda Genuine MTF. I must say it does shift smoother, even when cold.
