I just switched to Royal Purple Max-Gear 75w90 on the rear end of my Dodge 2500. The truck has a limited slip differential and I was told the RP already had a friction modifier in it so I should be all set. Wrong.
After a few hundred miles the LSD started to chatter around corners. I spoke with a Royal Purple tech and was told to add some additional Mopar friction modifier 1/2 a bottle to start and then the full bottle if I was not happy with the results after adding 1/2.
The first 1/2 of the bottle helped but not much. After adding the rest of the bottle the chatter was gone from the LSD and the function does not appear to be comprimised due to the addition of extra friction modifier.
I am just curious if anyone has had similar experiences with the Royal Purple gear lubes?
