Patman
Staff member
I found this report on LS1Tech.com:
Just got my oil report from Blackstone Laboratories today. This is the Royal Purple 5W30, I ran it too long at 5,600 miles. Overall I'm not happy with it. After my heads/cam get installed I will run some other oil and get another report and make sure cooper and iron are down!
Aluminum: 6
Chromium: 3
Iron: 33
Copper: 80
Lead: 7
Tin: 3
Molybdenum: 108
Nickel:1
Manganese: 4
Silver: 0
Titanium: 0
Potassium: 0
Boron: 13
Silicon: 15
Sodium: 661
Calcium: 1415
Magnesium: 814
Phosphorus: 773
Zinc: 998
Barium: 0
SUS Viscosity @ 210F: 57.7
Flashpoint: 400F
Fuel %: Antifreeze: 0
Water: 0
Insolubles: < 0.5
We are not sure what additives Royal Purple 5W/30, uses but we strongly suspect the copper and sodium are from the oil. Certainly molybdenum and the elements from calcium on down the list are additives. Sodium is an element common to ethylene glycol. Since we see no other signs of contamination problem, we will go with sodium being an oil additive for now. All metals other than copper read at normal levels. Iron was a little higher than expected but was not up in the problem range after 5,600 miles oil use. Air and oil firtration are okay.
[ August 01, 2002, 06:18 AM: Message edited by: Patman ]
Aluminum: 6
Chromium: 3
Iron: 33
Copper: 80
Lead: 7
Tin: 3
Molybdenum: 108
Nickel:1
Manganese: 4
Silver: 0
Titanium: 0
Potassium: 0
Boron: 13
Silicon: 15
Sodium: 661
Calcium: 1415
Magnesium: 814
Phosphorus: 773
Zinc: 998
Barium: 0
Flashpoint: 400F
Water: 0
Insolubles: < 0.5
