This bike has 9,640 total miles with 5,240 miles on the oil. This is RP's normal 20w50 rather than their Motorcycle blend and was changed when this sample was taken. Stock engine and air cleaner with the 10 micron Harley-Davidson oil filter. The oil did thin down to a 40 weight however. I would like to hear comments on this issue and how I should respond.
First post by the way and thanks in advance.
Blackstone's Comments
quote:
No problems showed up in the initial sample from your Harley. All wear read close to
averages for this type of engine, which is a very good indication of normal wearing parts. The universal
averages show normal wear after 3500 miles on the oil. Insolubles (oil oxidation due to heat, use and
blow-by) were low at 0.2%, showing good oil filtration. No fuel dilution or coolant was found. Silicon
was okay indicating adequate air filtration. The TBN was 5.6, strong - 1.0 is low. Viscosity was in the
SAE 40W range. Other than the low vis - the RP oil is doing a nice job.
quote:
ALUMNUM = 8
CHROMIUM = 1
IRON = 22
COPPER = 16
LEAD = 3
TIN = 0
MOLYBDENUM = 90
NICKEL = 0
MANGANESE = 1
SILVER = 0
TITANIUM = 0
POTASSIUM = 0
BORON = 28
SILICON = 10
SODIUM = 6
CALCIUM = 2995
MAGNESIUM = 125
PHOSPHORUS = 876
ZINC = 1165
BARIUM = 2
Sub Viscosity @ 210 F = 76.3
Flash Point = 410
Fuel = Insolubles = 0.2
