In what capacity? Did they do any lab vs real world testing like some SAE studies have done? Tell us how all these ISO and SAE test standards that have been around for decades and used over the entire globe in the filter industry are all wrong compared to how those filters perform in the real world.I am not here to debate. I did some time with a two major filter companies and see how the internet throws off everything into extremes. With some members, its the same ******** argument over nothing, OVER and OVER again. Look at me cause I know better. Some think they do and they don't.
There have been SAE studies that showed a good correlation between lab filter efficiency testing and oil cleanliness and wear in real world use. The only way to know how oil filtration and resulting oil cleanliness effects wear rates it to have a very controlled study. Not a few UOAs on some uncontrolled vehicles.BTW, one of the best UOAs that I've seen is without a full flow filter which is pretty scary when so many have trust in UOAs and there megamicron super filters, especially when many full flow filters spend a considerate time in bypass and load up quickly. I remember some 'non bench tests' but real manufacturer 'engine tests' where typical filters were loaded up within 3000 miles. There is a relationship with engine soot and test powders but its not as close as we want to believe. I wish all my engines produced standardized ISO quality debris for my filter.
How do you know the filters loaded up quickly and the bypass valve was open a considerable time? Where those filters instrumented on the vehicles, or were those filters tested in the lab to determine their flow vs delta-p and how much loading they actually had?
If there were accurate pre and post filter pressure gauges (or simply a delta-p gauge setup) you would certainly get all the info you'd need to see what the delta-p across the filter is doing. How would that "provide less data than most want to believe". There is no magic here.And, the only way to know if a filter is in relief or not, or partially in relief, is to put a sensor on the bypass valve. Yes, the pre/post gauges provides less data than most want to believe. The data we use here, other than for internet debates, is borderline useless concerning bypasses, and why I don't bother running pre/post PSI gauges on my filters on daily drivers.
When Motoking was active here, we got some good technical information from him that Fram never divulges to the public, like the flow performance of the Ultra. And when it was tested by the independent lab (link given in post #11) it showed it flowed very well just as Motoking relayed to us here when asked for that performance information. Also, way back Purolator actually ran a flow vs delta-p test on a PureOne when asked to (back when their engineers actually responded with tech info to emails sent to Purolator), and the long standing myth that PureOne oil filters were "too restrictive because they were so efficient". That's again why "flow over filtration" is a long standing myth.If anyone wants to debate filtration, spend a few years at Wix, Fram, Champ, Donaldson, Luberfiner, or Purolator, and definitely not in the 'marketing department'. Come back when more aware especially if spending time in R&D, testing, or failure analysis. This forum doesn't see 1/100 of the proprietary data from filter manufacturers. We get the best of the marketing aspect, and testing data no more better than 'projectfarm' which seems to be slandered often here.
If an oil filter is designed correctly it can be high efficiency, high holding capacity and good flowing (meaning low delta-p vs flow) all at the same time. Not all oil filters are designed that way, but most here know which ones are by gleaning bits and pieces of technical info over the years, and from data like shown in the ISO testing link given in post #11. Have you even read that thread? There's a lot of good technical discussion there, and some things shown to be true (that have been denied by nay-sayers for years) about how oil filters become less efficient as the load up (instead of the myth that they get more efficient), and that oil filters that rate higher in the ISO efficiency test are more likely also the filters that shed (from delta-p) a lot less already captured debris as they load up, which IMO is something important in the performance of any filter.
