Originally Posted By: HKPolice
Wrong. Valvoline's oil engineer stated in a video that running thicker oil than recommended will cause hot spots to become hotter. If you knew anything about engine cooling you'll know that oil flow is crucial to cooling areas of the engine that coolant can't reach such as RIGHT UNDER THE PISTON where oil squirts to.
Will it blow the engine up? Of course not, but why argue with engineers that actually designed the engine and wrote the manual.
5w40 is too thick for this regular NA 2L engine. Just keep using 0w20 or go 10w30 for better NOACK. AFAIK, the factory recommended fil is 0w20. Running thicker oil DOES have its downsides because it doesn't flow as well so hot spots in the engine will run even hotter.
What so many fail to understand is that " the engineers..." aren't necessarily the ones who "recommended" the 20 grade (weight ) oil...
And do you think a 40 grade at operating temps doesn't SQUIRT...? Or FLOW...seriously... ?
Again, at operating temps the difference between a 20, 30 or even 40 are not that huge. Why people seem to think a 40 or 50 grade is like molasses is curious. It's not, really... it's just a little thicker...
How does that Mustang GT running a 5w50 not just blow up, with that ungodly thick oil...? Their not driven on the track ALL the time, are they?
And did you know that at 40* C , your 20 grade oil is 3x thicker than the 50 grade is at operating temps...? And the engine runs just fine. For the first 15 minutes or so, EVERY OIL is way too thick, and the car survives... who'd have thunk...!
