Once again, I apologize that this was not posted in the preferred format.
I tried several times but just can not get it right.....
Shell Rotella T6 5w-40
19 hours in use
210 hours on motor
sample taken on 10-12-15 at oil change
no oil added between changes
aluminum 1
chromium 0
iron 4
copper 1
lead 0
tin 0
molybdenum 65
nickel 0
manganese 0
silver 0
titanium 0
potassium 0
boron 56
silicon 3
sodium 5
calcium 797
magnesium 1,241
phosphorus 1,097
zinc 1,299
barium 0
SUS viscosity @ 210*F 67.6
cSt viscosity @ 100*C 12.32
flash point 335
fuel 2%
antifreeze 0%
water 0%
insolubles TR
TBN 8.2
The 2% fuel was most likely due to extended cruising at low RPM before oil change.
I did run the engine hard for a few min right before changing the oil but the oil was barely even warm when I changed it.
19 hours in use
210 hours on motor
aluminum 1
chromium 0
iron 4
copper 1
lead 0
tin 0
molybdenum 65
nickel 0
manganese 0
silver 0
titanium 0
potassium 0
boron 56
silicon 3
sodium 5
calcium 797
magnesium 1,241
phosphorus 1,097
zinc 1,299
barium 0
flash point 335
fuel 2%
antifreeze 0%
water 0%
insolubles TR
TBN 8.2
