Just thought is wasn't for gasoline enginesYou could do far worse than T5 in that engine. Run it without worry.
I run diesel oils (HDEO) in all of my outdoor power equipment. They're more robust than most passenger car oils, and still fairly cheap. Don't let the word diesel scare you away. I agree with @ripcord that it is ideal for your usage.Just thought is wasn't for gasoline engines
Why not year round in Miami?I'm thinking about switching to 15w40 for summer use in Miami.
but since it’s a new engine I don’t want to void the warranty.Why not year round in Miami?
I would use up the 10w30, and then switch to the 15w40 HDEO if it were me.Why not year round in Miami?
I prefer 15w40, I have been exercising my generators with it every month andI would use up the 10w30, and then switch to the 15w40 HDEO if it were me.
Your Honda will be Okay. But if your not comfortable, just run the 10W-30 you have on hand. GCV 160 is a tough engine. Only needs some oil in the sump and it runs like a champion - Okay, I own oneI had given it some thought
I have a couple of more hours break in and then I’ll try the 15w40. I really like that oilYour Honda will be Okay. But if your not comfortable, just run the 10W-30 you have on hand. GCV 160 is a tough engine. Only needs some oil in the sump and it runs like a champion - Okay, I own one
I’ve never tried T5 but I hear it is an outstanding oil!T5 is what I run in my B&S 20 HP Twin. A good stout oil in my opinion. Ed
I’m running Redline 5W-30 in mine now, then I’ll go back to T4 10w-30 or Delo SDE 15W-40.I have a couple of more hours break in and then I’ll try the 15w40. I really like that oil
and my 10 hp Subaru and 9 hp BS Vanguard engines seam to like it as well.
I have heard of Delo XLE 15w40, there are so many great oils it’s hard to put myI’m running Redline 5W-30 in mine now, then I’ll go back to T4 10w-30 or Delo SDE 15W-40.
The "best one" is the T5 10W-30 you have...without the S rating.I have heard of Delo XLE 15w40, there are so many great oils it’s hard to put my
finger any one particular oil.
