The details:
Truck: 1999 Ford F150 Supercab Flareside 4x4
Engine: 4.6L 2V SOHC V8
Oil Filter: Napa Gold 1327
Air Filter: Fram (in use for 6000 miles). Not happy with the "new and improved" design of this filter.
Driving: 60/40 Highway/City. Couple of light trailer towing hauls. Fair amount of Gravel Road driving.
Weather: From January through May in Minnesota, a bit warmer than usual.
Analysis: Blackstone
Rot= Shell Rotella T Synthetic
Hav = Texaco Havoline
The last analysis after a 1 year run of Shell Rotella T synthetic 5w40 in my modular 4.6l V8. Some predicited doom for my motor with such a "thick" oil, especially given my climate.
My thoughts are that wear tracked slightly lower versus a 5w20 or 5w30 used year around. I emphasize the slightly, as there were no siesmic shifts. However, I will comment that this last interval was likely easier on the Rotella than the simialr periods using 5w30 or 5w20, as it was just not nearly as cold. I have not tabulated up weather stats, but will shortly. I'm positive that the number of below zero nights was much less!
Vicosity is right on the 30 weight / 40 weight border - it did shear a bit. TBN held out nicely and could go further there.
What I was never happy with was my fuel mileage. I haven't tallied final numbers, but the mileage loss was not pretty. I'm guessing it ended up around a 5% drop from running a 5w30 or 5w20 oil. Not good!
I have switched to Citgo Supergard Synthetic 5w30. Fuel mileage and resposiveness are already up noticably.
Fire away...
My Comments:code:
Oil: Rot Rot Rot Hav Univ.
Avg.
Grade: 5w40 5w40 5w40 5w20
Date: 6/05 1/05 9/04 5/04
Mi on Oil: 6117 6132 6027 6134
Mi on Unit:120811 114694 108561 102533
Make Up qt:1.0 0.5 0.5 1.5
Aluminum 5 4 3 5 3
Chromium 1 1 1 2 1
Iron 22 18 16 28 15
Copper 4 5 9 3 6
Lead 0 0 1 1 1
Tin 0 0 0 0 0
Moly 10 6 16 173 46
Nickel 2 1 1 2 1
Managnese 0 0 0 0 1
Silver 0 0 0 0 0
Titanium 0 0 0 0 0
Potassium 0 0 1 2 1
Boron 0 1 0 18 48
Silicon 12 10 11 17 16
Sodium 6 4 5 6 6
Calcium 3460 3322 3615 2141 2165
Magnesium 14 10 9 27 201
Phosphorous1117 808 930 740 773
Zinc 1267 1022 1068 884 931
Barium 0 1 2 0 1
Vis 13.5 13.7 14.7 8.3
TBN 3.0 3.1 4.3 1.6
Flash 410 400 400 405
Fuel 0 0 1.0 0
Glycol 0 0 0 0
Water 0 0 0 0
Insolubles 0.4 0.5 0.5 0.4
Fire away...
