Rotella T Syn 5w40 v/s M1 5w40 or 0w40, cleaner?
CO
Land Rover buddy at the office here said that the Rover guys are saying M1 keeps engins cleaner, so he's switchnig to M1 for a cleaner engine from Rotella T Syn. Im not thinking RTS is cleaner, but would think they are dead equal. Thoughts?
Colorado
Hmmmm I think it is a wash. Both Synthetics do a very good job of keeping the engines clean. But think about this....Rotella is designed to go long, long in a commercial diesel engine and keep it clean and manage soot.
OVERKILL
$100 Site Donor 2021
Ontario, Canada
So is M1 TDT 5w40/Delvac 1. Do a search on Doug Hillary.
Nederlander75
CO
Thats what Im saying. Unless you put these to enduro track use you wont see a difference and any difference may be simply application difference.
Dallas
more reason to use this for my track car that runs 11.5:1 AFR in boost. I'm really torn between using this oil on the track because of everyone's uninformed, arm-chair quarterback opinion and the threat or suspicion of foaming with long 4k-7k rpm exposure for 30-minutes at a time. However the UOAs look good.
Billings, MT
VOA's I've seen on some Rotella T synthetic have been pretty low on calcium, so it's possible they don't clean as well as the M1.
Chicago
What engine is this? That's insanely rich even for a turbocharged engine at max load at redline.
Dallas
a built miata motor running 15psi through a gt2860rs, and the car sees track time. 11.5 is rich, but fat enough to compensate for 10% ethanol and keep EGT under 1300*F.
Texas
Foaming? The turbo Subaru autocrossers seem to love RTS. No complaints about foaming from them. The only possible (rumored?) foaming issue I've ever heard was several years ago in Powerstroke hydraulically actuated/electronically controlled injection systems, and I haven't even heard that recently. As far as "cleaning" goes, I'd be inclinede to think that M1's PAO base might inherently prevent deposits ever-so-slightly better (probably never detectable in the real world) but that RTS's Group III+ base is a better solvent for additives and might remove existing deposits ever-so-slightly better. Just a wild guess- I really think they're dead equal in every way you'd ever notice.
