The details:
Truck: 1999 Ford F150 Supercab Flareside 4x4
Engine: 4.6L 2V SOHC V8
Oil Filter: Wix 51327
Air Filter: Fram (in use for 24,000 miles). Filter still looks good.
Driving: 60/40 Highway/City. No trailer towing. Fair amount of Gravel Road driving.
Analysis: Blackstone
Rot= Shell Rotella T Synthetic
Hav = Texaco Havoline
Valv = Valvoline Durablend
With all the sucess we've seen 5w20 oils having in Ford Modular motors, I thought I'd take a year long shot at a 5w40 oil to see how it stacked up.
Based on this analysis, wear rates all track very closely with what I've seen out of 5w20 and 5w30 oils, especially when you take the milegae on each interval into account. The lone exception was copper, but given I switched to a HDEO, that may be due to some other cleaning going on in the engine. So, based on wear, I am happy.
I also very much like the TBN number, which shows this could go further in this configuration. Oil cunsumption was also decreased nicely.
AS far as other impressions, what I have not enjoyed is the fuel mileage. My fuel mileage is off by 4% relative to simialr periods of 5w30 and 5w20 and similar temperatures. The engine also "feels" a bit sluggish at times, but that could all be in my head. The mpg drop however, is defintitely more than a statistical tie.
So, at this point, an xw40 appears to work fine in the mod motor. I have paid a penalty in fuel mileage (ugh!). I put another batch of the Rotella T Syn 5w40 in, and will run it for another full interval, and continue tracking it.
If the current trend continues, I will likely switch back to 5w30 or 5w20 again next spring.
My Comments:code:
Oil: Rot Hav Hav Hav Val Univ.
DB Avg.
Grade: 5w40 5w20 5w20 5w20 5w30
Date: 9/04 5/04 1/04 9/03 6/03
Mi on Oil: 6027 6134 6004 5033 4984 4500
Mi on Unit:108561 102533 96399 90392 85359
Make Up qt:0.5 1.5 1.5 1.0 1.0
Aluminum 3 5 5 3 4 4
Chromium 1 2 1 1 1 1
Iron 16 28 20 12 14 16
Copper 9 3 3 5 4 7
Lead 1 1 0 0 0 1
Tin 0 0 0 0 0 0
Moly 16 173 200 2 3 44
Nickel 1 2 1 1 2 1
Managnese 0 0 0 0 0 1
Silver 0 0 0 0 0 0
Titanium 0 0 0 0 0 0
Potassium 1 2 0 1 2 1
Boron 0 18 23 1 1 49
Silicon 11 17 11 9 9 16
Sodium 5 6 4 3 3 5
Calcium 3615 2141 2067 2219 2496 2092
Magnesium 9 27 33 30 8 258
Phosphorous930 740 770 783 829 782
Zinc 1068 884 936 1007 999 947
Barium 2 0 0 0 1 1
Vis 14.7 8.3 8.3 8.9 10.3
TBN 4.3 1.6 1.9 4.7 1.8
Flash 400 405 395 425 400
Fuel 1.0 0 0 0 0
Glycol 0 0 0 0 0
Water 0 0 0 0 0
Insolubles 0.5 0.4 0.4 0.3 0.5
