Here's the latest on my Legacy GT. The Rotella is proving to be a solid choice for this engine. The copper is still a bit high, but I suspect that is an interaction between the Rotella chemistry and the big, copper oil cooler. The fuel is a bit high likely because the warm-up for this change was all at idle while I changed the coolant and P/S fluid.
Code:
Report Date 18-MAY-09
Lab Blackstone
Make Subaru
Model Legacy GT
Year 2008
Engine 2.5L Turbo F4
Miles On Veh. 30,016
Oil Brand Shell
Oil Series Rotella T
Oil SAE J300 10W-30
API SX CJ-4/SM
Miles on Oil 3729 ~2 months in service
***Elements***
Aluminum Al 3
Chromium Cr 0
Iron Fe 5
Copper Cu 16
Lead Pb 1
Tin Sn 1
Molybdenum Mo 2
Nickel 0
Manganese Mn 0
Silver Ag 0
Titanium Ti 0
Potassium K 6
Boron B 24
Silicon Si 14
Sodium Na 4
Calcium Ca 2252
Magnesium Mg 8
Phosporus P 1107
Zinc Zn 1501
cST @ 100 C 10.9
SUS @ 210 F 61.3
Flashpoint 375
Fuel % TR
Antifreeze % 0.0
Water % 0.0
Insolubles % 0.3
TBN N/A
Additives None
***Filters used***
Air Filter Subaru OEM
Oil Filter Subaru OEM
Location Reno, NV USA
Ed
Code:
Lab Blackstone
Make Subaru
Model Legacy GT
Year 2008
Oil Brand Shell
Oil SAE J300 10W-30
API SX CJ-4/SM
***Elements***
Aluminum Al 3
Chromium Cr 0
Iron Fe 5
Copper Cu 16
Lead Pb 1
Tin Sn 1
Molybdenum Mo 2
Nickel 0
Manganese Mn 0
Silver Ag 0
Titanium Ti 0
Potassium K 6
Boron B 24
Silicon Si 14
Sodium Na 4
Calcium Ca 2252
Magnesium Mg 8
Phosporus P 1107
Zinc Zn 1501
cST @ 100 C 10.9
SUS @ 210 F 61.3
Flashpoint 375
Fuel % TR
Antifreeze % 0.0
Water % 0.0
Insolubles % 0.3
TBN N/A
Additives None
***Filters used***
Ed
