Rotella Rebate, July 1st - Nov 30th
cptbarkey
$50 site donor 2024
texas
Rotella rebate has started again. Last few times I went with single jugs, and a 3 gallon bladder box, but this time opted for 2x - 2.5 gallons of T5.
I'm showing a screenshot with Walmart selected noting its in person only. I've seen folks make the mistake of buying it online, and curbside also does not count.
https://rotella.shell.com/en_us/pro...ewards.html#iframe=L2RpeS9PMjYxNS9mb3JtLmNmbQ
Brotella boys unite
That's a confusing screen shot.
Every product is listed as "One" and each product listing ends with the word "OR" in big letters.
It sure looks like you can only get a rebate on one, single product.
So, how does the "...up to an $80 gift card..." ever come into play?
See the top part where it says "limit of two."
Very timely.
In the spring rebate, I turned in a receipt for four gallons of T5, which qualified for $10 each. They summed them to the max rebate offer value of $40. So I don't think there's a limit on the number of items you can submit to get to the $80 rebate.
But that still begs the question. Can I submit for one $80 gift card or two?
They're including T4 which is not normal for these rebates. Sweet! :cool:
EDIT: T4 rebate available on
2.5 Gal jug
x3 1 Gal jugs (It says "3 Gallon Bottle" which I assume means x3 1 gallon bottles?)
5 Gal pail
Very timely.
Max rebate amount is up to $80 not $160
This rebate is limited to two rebates per address. You are capped by the "Up to $80" & "Limit two gift cards".
there is a T4 - 3 gallon bladder box (12 qts) similar to what Supertech used to do, I was successful getting a whopping $10 rebate last time for it. I recently used it in my project ram. It worked pretty well with the spigot straight into the crank, and was able to open the box and was quite surprised I only needed to squeeze a little more out.
We've been seeing more & more oil co's offering "Bulk packaging" to the end consumer so this is something new to me on the T4. Thanks for that information so no 1 Gal jugs qualify for rebate for T4.
