I have been doing a bit of searching about running a Diesel Engine OIl in my gas engine and couldn't exactly find an answer to any negative effects that additional additives would do to the engine components of gas engine, so i visited the Rotella site (oil i will be running) and emailed them.
my orig message.
"I'm wanting to switch to an Heavy Duty oil in my Gas-powered vehicle.
I was just wondering if any of the additional additives would have any
negative effects on any of the vehicle's components, specifically the
catalytic convertors"
Response from Rotella.
"With the introduction of API specification SM in late 2004, it was required that
the phosphorous content of motor oil be lowered to prolong the life of catalytic
converters in vehicles so equipped. Common anti-wear additives used in engine
oils are sulfur-phosphorous compounds, and the amount of zinc may be decreased
in SM-rated oils, as well.
Products like Shell Rotella T oils are formulated primarily for diesel engine
vehicles that don't (at least not yet) have catalytic converters, and contain
higher levels of phosphorous and zinc than gasoline-only engine oils. Hence,
Shell Rotella T oils only meet the API SL (and earlier) specifications for
gasoline engines.
If you want to discuss this further, please call us at 1-800-231-6950. Thank you
for your interest in shell products."
So what my take on this, is that its ok to use the product if your engine is specified to use SL and earlier specifications, and not to be used on newer vehicles that are specified to use SM rated oils.
my orig message.
gasoline engines.
