Rotella 10W/30; 3,065 Miles; 1999 Civic SI (191K)
Originally Posted By: CATERHAM
Looks good.
This dino HDEO sheared more than I would have thought although that's not a problem since a light 30wt oil is specified.
Try a 5W-30 next time.
how do you know its shearing? he used an oil additive.
LC20 dose as spec'd would have been ~ 4oz at initial fill, plus an oz every 1k miles
Perhaps 7% of the sump, is what I estimate? Looks as though LC20's visc is similar to a "20 wt oil". The Civic Si is a high revving little engine, perhaps that also contributes.
Either way, wear is low, no contaminants. No issues.
Oopss... You got me:)
I've been driving it conservatively because I'm trying to maximize the FE. I've been keeping it under 4K RPM or less.
Looks good.
I can't see adding just 4 oz of LC20 lowering the oil's viscosity much.
Moly 82
Boron 50
Could the moly and boron come from the LC20?
Virgin samples of Rotella 10w-30 show almost no Moly and very little boron....If I remember right.
Originally Posted By: KCJeep
I don't know what's in LC20. OP what oil was run prior to this?
Any inexpensive oil, such as Motorcraft and Supertech (Warlmart).
