Since the soot is coming from combustion, I don't think you'll see any changes unless you change the combustion part of the equation. Certain oils may deal with the soot better, preventing agglomeration for example, but the soot is still there and, I would think, still show up in a UOA.
Switching to an oil with a stronger additive package will also help reduce oxidation (I wondered about the high TBN AND the high oxidation) but I wonder if you need to start thinking about a bypass filtration system if you want extended OCIs. A tight bypass system (1-2um) will catch a lot of soot. Unfortunately, it will cause you to have to recalibrate on your UOAs, as it will skew metals readings downward. I'm sure Terry is up for that.
For myself, I don't hang on every minor change in ppm and use UOA primarily to track oil condition during extended runs. I just installed a bypass on a gas engine, which is in a very stable wear position right now, but I have a good snapshots of the oil with out it so can recalibrate pretty well. I've run 10K OCIs with that engine that could have gone longer (I have a great operational cycle, being rural and all our trips are 20 miles or more at 55-60 mph).
