RL 5W-20 - 5,000mi oil/12,000mi Maybach 57
Sarasota, Florida
2005 Maybach 57 delivered March 25th, 2005 with 175 miles on the odometer. I took a sample after driving 15 miles home from work with 400 miles on the clock. The car comes with a twin turbo 5.5 Liter V12. It has 550 BHP and 660 Ft Lbs torque but I put in a Renntech chipset that they tell me gives another 120 torque. Driving: spirited around town, some highway driving.
Again, the OEM is supposed to be Shell Helix Ultra. I do not have a VOA and I do not think it would have so much Moly in there. Terry said it is mostly from assembly of the engine parts.
The last column on the right side is the second run of RL 5W-20. After the 1st run of 5,000 miles I changed the oil and filter with a new fill of the same RL oil. I dropped the OEM oil at around 2,000 miles and started the 1st run of RL.
Now the car has 12,086 miles. But I traded it in on a Maybach 57 S, yet to be made.
____New OEM ______Red Line 5W-20____Red Line ____Red Line VOA____Red Line
_Unknown 400 Mi__With 2,500 Mi __With 5,000 Mi__New in Bottle___5,000 miles
Iron__________18_________13________23________1________17
Chromium ______1_________0_________1________0________1
Nickel __________0_________0_________0________0________0
Aluminum _____31________13________16________10_______17
lead __________2_________3_________12________0________2
Copper _______19________16_________16________0________9
Tin ___________5_________2_________4_________1________3
Silver ________0__________0_________0_________1________0
Titanium ______0__________0________0_________0________0
Silicon _______21_________12_______11_________7________8
Boron ________87_________9_________6_________2________2
Sodium ______13_________12________13________18_______12
Potassium _____5__________1________1_________0________2
Molybdenum __ 446________557______572_______617______590
Phosphorus ___1120_______1225_____1201_____1431______1317
Zinc _________1303_______1304_____1307_____1466______1445
Calcium _____ 1727_______2475_____2551_____2986______2848
Barium _______87_________9_________0_________1________1
Magnesium ____1124______170_______191_______11_______43
Antimony ______5_________2_________0_________2________0
Vanadium ______0_________0_________0_________0________0
Fuel %Vol _____neg______neg________neg_______neg______neg
Abs Oxid ______x_________x_________79_________x_______1449
Abs Nitr _______x_________x_________90_________x_______108
Wtr %vol ______neg_______neg_______neg________x_______neg
Vis CS 100C __11.4_______9.2________9.7_______9.2______9.8
SAE Grade ____30________20_________30________20_______30
Gly test ______neg_______neg_______neg______POS_______neg
TBN _________not done____x_________x_________x________x
Particles Counts:
>5__________44864____81592____90038_____18349_____31536
>10_________3703______4273____22902______3508______8282
>15_________318_______608______1050______1255_______270
>20_________109_______350_______136_______523_______92
>25_________42________252_______86________239_______46
>50_________5_________118_______18________27________8
>75_________1__________90________6________6_________4
>100________0__________64________2________1_________0
Ferrous debris__15_____18________5________X________12
Particle Volume__6_____24________22_______X________5
aehaas
PS- There were light brown colored spots seen on the camshaft and inside the valve compartment. These were there since new and have disappeared now.
Looks like most of your wear numbers have come down nicely. I'm still wondering where the aluminum is coming from.
When are you supposed to take delivery on the 57S?
I'm sure stuff is still wearing in. I haven't done any research on the Maybach's, but I'm willing to bet it has aluminum heads and and aluminum block. If the bores are not lined/sleeved, then it could very well have aluminum still wearing for break-in. As far as the heads, most cams ride on the machined aluminum bearings. There generally are no bearings.
The ETA for the 57 s is March. We are down to only 3 cars, no convertibles, but we will endure i am sure.
Note that the VOA of the Red Line has 10 of Al. It must be some sort of additive. Overall I like what I see and will probably stick with this oil for the new 6.0 L engine in the AMG version of the Maybach 57.
aehaas
So you've already turned in your car for trade-in but won't get the new one until March?
Yes. It was part of the "deal". It was really good for us so we could not complain that they wanted the current car back now.
aehaas
You must have supreme trust in your dealership and its creditworthiness to entrust what is likely a six-figure sum to them in the form of an unsecured loan for 5 months!
Depending on how the deal was structured, I'm sure the good doctor is well covered and the agreed upon value of his old 57 has already been applied to the purchase price of the new 57S.
Now, let's end the talk about the deal and confine this thread to talk about the oil and the car.
