Joe has it right. The heaviest wear is right under the ridge, typically only for the first inch of piston travel. That first inch is where the combustion pressures are greatest and the rings are blown against the cylinder wall the hardest.
The ridge is not new material. It is where there was no wear. The ring packs don't come up to the piston or the cylinder tops, so the wear starts where the ridge ends.
Because the rings never travel (and wipe) the full cylinder, sometimes (more commonly with carbs) you might find very some light carbon coating the ridge. It's typically fuel related. But that's about it.
I have never heard of synthetic oils causing excessive or unusual combustion chamber deposits any worse than a conventional would. It usually burns up just as well as the dino stuff does. NO oil can withstand combustion chamber temps. The oil film that a ring rides on near TDC is much thinner than a soap bubble - pretty darn close to boundary lubrication. The more common path for oil entry into the combustion chamber are the valve guides, not the cylinder walls.
It sure sounds like the mechanic/guy has overloaded on some hype and hasn't done much engine work.
