I am just trying to understand some of the differences in Euro spec oils vs some of the regular synthetic 5w-30 oils
for example, Is there really a big difference between the Penzoil Euro L and lets say rotella gas truck 5w-30 synthetic oil.
what would be the down side or negative effect to running a 5w-30 dexos 2 oil in a non turbo v6 porsche caynenne? I can see where maybe a turbo V8 would be more demanding on oil but is it really that important for a non turbo v6? I know it specs a c30
BTW- I am using castrol Euro now and plan to continue. Just really wondering how much of a difference there is
There are numerous threads about this.
But here it is:
First of all, you are driving German car. That means car designed, engineered by Germans, and they care about driving conditions and culture in South Carolina same as you guys care about driving and culture in Lower Saxony. So, they engineer engines and cars the way their tradition drives trends.
They spec everything for their needs. That means that your V6 is designed, specd. etc. with their roads in mind, including prolonged high speed runs etc. Combine that with very stringent emission requirements, environment requirements etc. in EU, and you end up with oil that should be able to do 120mph for 2hrs and do OCI some 15k miles. Also, it has to stay in grade, and have very limited amounts of deposits, very low oxidation (long OCI) but usually (or before a must) have HTHS above 3.5. You get very sophisticated oil. And it is not only Euro manufacturers. In Europe for example Toyota's (Lexus) with engine like mine in Sienna (or close version) run on these oils.
Europeans took recently different approach, spec. different oils for different markets, mostly driven by difference how emissions are calculated. So in US you have CAFE, where thin oil help to achieve, while in EU equation is different, so heavier oils are OK.
Now, on more practical note, those specifications are more stringent, involving much more than just HTHS, Noack or stay in grade requirements. They have specific engine tests, so if it says Porsche A40, that means oil was tested by Porsche for their applications (and it is very tough test). Regular API or ILSAC GF oils are, well, one size fits all.
