Removing Engine Varnish
Ontario, Canada
I'm overhauling the head and block and curious if Paint Thinner is a suitable cleaner (low cost) that I can use to drench and clean all the parts to remove the varnish & sludge.
I'll be using an engine cleaning gun hooked up to an air supply plus a regular parts cleaning brush.
Any methods or tips you can suggest to clean these components would be appreicated.
Berryman B-12 Chemtool should remove the varnish. But it's not an inexpensive proposition, though.
