94 Land Cruiser
411,000 mi
1 qt first 2000 to 3000 mi. It gets down to about 1qt per 1000 mi +- at about 9000 mi +- oil change. It starts out with fresh oil and 1 qt MOS oil additive from Liqui Moly. I assume that as the consumption of oil is used and when I add more oil the ratio of MOS is decreased and that increases consumption. But even without the use of MOS, the consumption is increased as the oil gets older.
Yes, the cats must be past their normal life, but the same could be said about the motor in the Land Cruiser but it still runs on.
I gave up replacing the O2's and it now runs default mode with no O2's checking the fuel ratio. The EGR is not working either, not much to fix that though. With all the miles and no O2's, the LC has more power than it has had in the past. May have to due with the O2's always getting fowled??? Not sure.
I did play with unplugging the O2's and many miles later plug them back in and they worked fine (no codes) for several months before finally dieing. Was told that some have had luck with removing them and heating with propane torch to clean them, I have not tried that.
Back to cleaning the Cats and O2's. When I had the cats and O2's off, there was a light brown/grey glaze on them. I would assume its the oil??? With the O2's unplugged, I get black soot inside the tail pipe. Maybe running a little rich?
When I tried to pass emissions 3 years ago, I got very close with new O2's and a working EGR. A new set of cats would of done the job.
I was just thinking of removing the cats, I have SS bolts on the cats and its an easy job removing them now, and cleaning them somehow, just to see if I can pass or even get close to passing than I did 3 years ago. If it works, then I have saved a few buck, if not, then all I have to do is buy new cats.
