- Joined
- Dec 27, 2021
- Messages
- 4
Curious if you guys have any resources or data on more practical filtration of oils for reuse in a temporary test application? We have a large dozer that got coolant in the trans to a large degree. It sat for quite a while so the majority of coolant was able to be drained off the bottom, but it obvious affected the oil and the viscosity of oil is thick, and is playing hell with filters and pressure readings.
We would just change the oil but there is indication we may need to tear into the trans anyway so it is like throwing money out the window. I'd just like to get the oil viscosity in the window for tests. We are not talking about stress tests, just ensure we have mobility. Obviously we could go to extremes to clean the oil, but I am curious about any reasonable approaches? I had the thought to just cut the oil with diesel as it might do some good to clean the trans parts a bit, but elsewhere I was cussed out for that. I feel I have some valid reasons in that approach but I digress.
