wemay
Site Donor 2023
M1EP is a 20K mile oil.super long drain = 15k+ as required by many european long life oil specs
10k miles of good highway driving could be basically equivalent to 4k miles of short commute driving (like I do with my car in the summer). People seem to forget not all miles are equal. You need to put it into context.There's no point running M1EP if I'm draining at 7,500-mile intervals. M1 vanilla is rated at 10,000 miles and fine for most drivers.
Good points. For about $2-$3 more for a 5 qt. jug of EP, [@ Walmart regular price, sales can close the gap] I see no reason not to use EP. Overkill or not.10k miles of good highway driving could be basically equivalent to 4k miles of short commute driving (like I do with my car in the summer). People seem to forget not all miles are equal. You need to put it into context.
A lot of my friends and family drive such short commutes if they wanted to go 6k miles they should probably use EP, although any oil is going to be have a lot of fuel and moisture in it by that point.
Yes it could be... maybe/maybe not. But your point is correct and well taken, I shouldn't just say "ABC oil is good for ### miles" as a blanket statement. For some reason I assume people follow the owner's manual maintenance intervals for normal service vs severe service (or the OLM), which as we know is not always the case. I don't think it matters whether the oil used is regular or long-life, the actual use of the vehicle / driving habits should determine the service intervals. And I would not use 7.5k mile service intervals if my driving habits qualified as severe service.10k miles of good highway driving could be basically equivalent to 4k miles of short commute driving (like I do with my car in the summer). People seem to forget not all miles are equal. You need to put it into context.
I look at the normal/severe service an extreme oversimplification. Even it is too much for a lot of people to understand.Yes it could be... maybe/maybe not. But your point is correct and well taken, I shouldn't just say "ABC oil is good for ### miles" as a blanket statement. For some reason I assume people follow the owner's manual maintenance intervals for normal service vs severe service (or the OLM), which as we know is not always the case. I don't think it matters whether the oil used is regular or long-life, the actual use of the vehicle / driving habits should determine the service intervals. And I would not use 7.5k mile service intervals if my driving habits qualified as severe service.
