So I've been doing research on oils, OCI etc. for our new Prius V(an). I share the same powertrain as G3 Prii, so I'm focusing on those, instead of Gen2 since they used 5w-30, then the Prius debacle forced Toyota into offering 2 years maintenance.
Most of the threads were talking about oils for GenII Prii or SM oils. http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=2390341#Post2390341
Holy cow! Sombody went 25k on Amsoil in a Gen3-
http://www.bobistheoilguy.com/forums/ubb...rue#Post2084106
Luckily Critic did most of the recent footwork. Thanks Critic, I've read most of your recent Prius posts (there's alot).
So a few thoughts:
Unless someone convinces me Toyota is superior I'll go M1 since I like the brand and prefer to support them over my local Toyota dealer. WalMart has the M1 0w-20 Advanced Fuel Economy for $25 a jug. $5 @ qt is tough to beat for ANY full syn.
My questions:
Should I install a magnetic drain plug? Cheap ebay ones are $8, the GoldPlug is $18. I know magnetic plugs are a great idea, but I don't want to create any sealing problems when using OEM washers.
Can I use my last 3 cases of M1 0w-40? Being in California we'll get a few days of 30F this winter and a few days of 100F+, so I don't think I'll be using the full range of this oil. I may just save this for neighbors BMW. It's too good to flush for short intervals.
I'm planning on oil change at 1k to flush break-in materials and then letting the dealer do the 10k oil changes and I do the 5k oil changes. Seems like around 10k oils are doing just fine, but silica and aluminum build up. At ~$30 an oil change I don't mind a shorter OCI.
Lastly Critic I'm going to start researching tranny fluid changes. Every 15k?
Feedback is appreciated!
So a few thoughts:
My questions:
