- Messages
- 799
- Location
- Washington, DC
Here is the analysis I did on mobil 1 5w-30 after 10K , now I'm running mobil1 10w-30(8k so it is almost time to change) but both of those are thin 30 weight and I'm wondering if my lead wear is a bit high because of this. My V6 has a 7000 redline and I like to rew it form time to time.
Will heavier weight oil help reduce my lead wear?
I'm thinking of either mobil1 0w-40 or new castrol 0w-30?
What do you guys think?
UNIT 2000 MAZDA 626 LX-V6
MI/HR ON OIL 10,000
MI/HR ON UNIT 60,000
SAMPLE DATE 4/6/2003
FIRST NUMBER IS MY OIL AND SECOND NUMBER IS UNIVERSAL AVERAGE
ALUMINUM 7 4
CHROMIUM 2 1
IRON 33 12
COPPER 7 6
LEAD 23 5
TIN 0 13
MOLYBDENUM 75 0
NICKEL 1 0
MANGANESE 1 1
SILVER 0 0
TITANIUM 0 0
POTASSIUM 2 0
BORON 108 38
SILICON 11 9
SODIUM 9 6
CALCIUM 2951 1304
MAGNESIUM 73 481
PHOSPHORUS 801 747
ZINC 963 880
BARIUM 0 1
SUS VISCOSITY @ 210 ºF 64 55-62
FLASHPOINT IN ºF 415 >365
FUEL % <0.5 <2.0
WATER % 0 <0.05
ANTIFREEZE % 0 0
INSOLUBLES % 0.04 <0.6
LAB COMMENT:Nothing too unusual showed up here. This oil was run quite a bit longer that what we
normally see and this is the reason for most of the high wear. The universal averages column shows typical wear from this type of engine after 4,000-5,000 miles on the oil. Lead at 23 ppm shows mildly high bearing wear, though everything else looks okay. The TBN was 3.5 which is low, but not a problem. 2.0 or less is considered a problem. The oil started at 10-11. No fuel or anti-freeze was present. Suggest going 11,000 next oil and resample at that point to monitor.
