Hi guys. I found this Redline "testimonial" on another board while browsing web in search of any technical data on Swepco oils. I think that this info is pretty interesting and does seem to be rather truthful. Your rational and substantiated opinions (as well as direct knowledge) are, as always, welcomed.
Hi all, not that I like open this old can of worms, but -
I used to love Red Line trans oil, run it in my Scirocco 16V, my Vanagon
trans, and it seemed like the best available- **Until Last Night**!!!
Background:
While at S Car Go, (www.scargoracing.com) a shop in Marin county that
prepares Porsches for racing, builds custom engines, headers, you name
it! They have one that puts out 500HP at the rear wheels!. Indeed they
are widely known in Porsche racing circles, and do most excellent work.
The Point of this message:
I noticed that the only kind of oil in their shop is Swepco. One of them
had a transaxle apart on the bench, and I asked him his opinion of Red
Line vs Swepco. He told me that Red Line breaks down into a chalky
deposit on the parts, and leaves a thin liquid behind. He then showed
me, on the parts he was working on, exactly what he just told me. He
scraped the goo deposit off of a gear, and I could see that the stuff
coating the parts was red, and there was a layer of what looked like
watery oil on some parts. He also told me that he can take one look and
tell what was run in a gearbox, and sees a lot of Red Line-lubricated
trannys come in broken.
They run ONLY Swepco oils and lubricants in these awesome, beautiful,
hand built, ex-freaking-spensive machines.
I'm sold. It's Swepco from now on for my trans oil from now on, and if I
upgrade from Mobil 1 Synth in my engines, it will be to Swepco. I'll
even look for their greases for the important stuff...
And another one:
Here, let me open the can of worms a little further! A while back (actually
about 2 years or so now) I was having a problem with the 2nd gear sychro in
my trans and was told that Red Line would not fix the problem but would help
to make it better so I used some Red line in the trans. Not only did it
make my 2nd gear grind worse, but it leaked past all my seals so quickly
that I developed a whine (low fluid = bad bearing(s)) before I knew the
trans was low. I replaced the sychro but wasn't about to replace all the
bearings to fix one light whine so I started running Mobil 1 and it helped
quite a bit but it still has the whine. I posted this to the list and
everyone thought I was crazy to say that I wouldn't use "That over priced
red crap" in my trans again. Thanks for this post because it not only
reinforces my feelings on Red Line in general but reminds me how
commercially wipped people are. I like performance and durability and if I
have to pay a little extra for that then fine but there is also performance
and durability is things that are not name brand or something that isn't
pasted on the side of a Nascar or Rally car. I think people get lost in the
hoopla myself!
Regards,
Background:
And another one:
hoopla myself!
Regards,
