Hi guys,
Finally I got my result from Blackstone. It took 3 weeks for the mail to deliver the sample. This is a Redline Power Steering Fluid. I changed it from a factory filled about 10-11 months ago. Pontiac Grand AM with 2.2L engine. Factory fluid was black and looked heavily oxidized at 18.5k miles. This sample was taken at approximately 22.3k miles. I changed fluid using turkey buster method for reservoir. System takes .7 liter; in total I put through the system 1.5 liters.
I decided to sample this fluid because steering just didn't feel right. It wasn't smooth; I could literally feel how components worked. This Redline fluid after 4k miles looked very, very dark, almost black. I didn't expect such poor result form it considering it was slightly pink new.
I changed fluid to Valvoline Synpower Blend PSF. I put 2 quarts through the system using drain-refill. I also added a bottle of Lubegard Power Steering Protectant. Now steering feels like I always thought it should - very soft, smooth, and quiet operation. Although I generally dislike Valvoline products this particular one exceeded my expectations. Way better than Redline. I highly recommend Synpower to anyone who has a car which calls for GM approved PS fluid.
I'll try to get refund from Redline. At least I got my analysis to confirm its performance. No more Redline products for me.
From now on I'll just stay with recommended and approved lubricants from major oil companies. That was enough experimenting for me... (Especially with Redline products).
As a side note: Additive levels seem quite high. It would be interesting to see VOA on Honda and Pentosin power steering fluids. If anyone could do it it would be great.
Comments from Blackstone are below.
Regards,
First column - tested result. Second - averages.
Flashpoint: 420 F (pretty good)
Insolubles: 0.3* (flagged)
This could be factory fill fluid, so we don't know if the silicon is from silicone used on parts at the factory, or if it is abrasive dirt contamination. Universal average's show typical wear from a power steering system. Copper (bronze parts) was high in your sample but the other metals appear at normal level. Insolubles were quite high, so this 10W oil appears oxidized. No moisture found.
Suggest having this P.S. fluid changed out to reset the metals and to get rid of the insolubles, which are probably free carbon, and which are probably abrasive.
Regards,
Viscosity: 46.8 SUScode:
ALUMINUM 1 2
CHROMIUM 0 1
IRON 15 32
COPPER 20* (flagged) 2
LEAD 3 1
TIN 0 0
MOLYBDENUM 2 0
NICKEL 0 0
MANGANESE 3 0
SILVER 0 0
TITANIUM 0 0
POTASSIUM 0 0
BORON 24 20
SILICON 24* (flagged) 4
SODIUM 7 1
CALCIUM 2695 21 ???
MAGNESIUM 12 10
PHOSPHORUS 2191 297 ???
ZINC 2789 245 ???
BARIUM 0 1
