MolaKule
Staff member
These are VOA results for comparison for
the Redline MT series of Manual Transimission and Transaxle lubes.
Redline MT-90 5/12/2003
Metal
Iron (Fe) 2
Copper (Cu) 0
Chromium (Cr) 0
Aluminum (Al) 3
Lead (Pb) 3
Tin (Sn) 6
Silicon (Si) 15
Sodium (Na) 18
Potassium (K) 21
Molybdenum (Mo) 1
Phosphorus (P) 2410
Zinc (Zn) 2750
Calcium (Ca) 2840
Magnesium (Mg) 11
Physical
Water (W) N
Fuel (F) /
Antifreeze (A) /
Viscocity At 40 C (V40) 0
Total Acid Number (Tan) 1
Total Base Number (Tbn) 3
Viscosity At 100 C (V100) 14.3
Particle
Redline MTL 5/12/2003 Analysis by Dyson
Metal
Iron (Fe) 1
Copper (Cu) 0
Chromium (Cr) 0
Aluminum (Al) 3
Lead (Pb) 3
Tin (Sn) 5
Silicon (Si) 25
Sodium (Na) 21
Potassium (K) 11
Molybdenum (Mo) 1
Phosphorus (P) 2520
Zinc (Zn) 2820
Calcium (Ca) 2860
Magnesium (Mg) 11
Physical
Water (W) N
Fuel (F) /
Antifreeze (A) /
Viscocity At 40 C (V40) NR
Total Base Number (Tbn) 4
Viscosity At 100 C (V100) 11.2
Iso Code Rating (Iso) 19/12
These Manual Gear Lubes also have the new Boron additives, not tested.
