Redline MT-85 (44,802 miles) Genesis Coupe
TX
Probably 90% highway at or above 70mph, frequently cruise on toll roads at ~100mph for extended distances in Texas heat.Always sees a WOT pull to the redline daily when it is warmed up. Previous fill was the same Redline MT-85 oil at 34,500 miles on the sample. Did not have a magnetic plug installed for the sampled analysis but now I do. Will probably run 40,000 miles maximum on the next sample. Is it common for aluminum to leach from the transmission housing? Transmission still shifts the same, there wasn't any difference that I could tell when the new fluid went in either. I've used Redline for the past 110k+ miles in my Genesis. Thoughts?
Malaysia
Fe trending higher, and that's possibly avoidable. Application may require upgrade to 90 or beyond. Any indications of operating temperature ?
Lethal1ty17
TX
Nope. I don't think there is even a single sensor in that transmission...maybe a speed sensor but that's it. I've asked if it is normal for the aluminum to leach, waiting for a response.
MolaKule
Staff member
Iowegia - USA
300 to 1000pmm deltas on Calcium, Phos, and Zinc seem excessive. If this is the same fluid used throughout and no additives have been dumped in it, then have them retest.
Lethal1ty17
TX
Two different batches of oil were sampled, but both were nothing but Redline MT-85 each time.
MolaKule
Staff member
Iowegia - USA
OK, here on BITOG "batches" means something different. In the oil industry a "batch" refers to a specific production run of say 50,000 gallons of lubricant of a specific mix on a specific date and time, and is stamped on the bottle for tracking and QC. Now, were these analyses shown from the same set of bottles of MTF?
jaj
Vancouver, Canada
The most recent test shows most additives about 1.3x higher concentrations the previous sample, so perhaps the previous run had hold-over dilution from the oil that was in use before that.
Lethal1ty17
TX
The first oil sampled was produced by Redline sometime in late 2013 or 2014, I cannot remember, but I drained it and sent it off in 2016. The second oil sampled (the most recent) was produced by Redline in 2016 and sent off for an analysis a few weeks ago. Hence why I said different batches. Both samples were Redline MT-85. They may have tweaked the formula over the span of a few years.
The fill before that was 2qts of Redline MT-85 and 0.3qts Redline Lightweight Shockproof.
