Redline 7.5K mile UOA; Ford 6.2L
Second test of Redline 5W-30
What you think ?
Thanks
Linear wear ppm / miles just looking at the numbers.? I could be wrong though.
Got lots of good stuff in it, but doesn’t seem much different than most other UOAs as far as wear goes.
Which is exactly in line with what the analysis company says, that there is no statisticaly valid UOA difference between any appropriately rated oil. It also supports the notion that a UOA is not an appropriate tool to determine wear.
Kind of puts 99% of all the UOA posted on this site into perspective.
What do oils with either zero or little moly use as anti wear now? Titanium (like Castrol) or something else?
When TAN and TBN equalizes it is not good. When TAN pass TBN it is bad. Redline is not ordinary oil. It is designed as performance oil. That mean shorter OCI’s bcs. higher oxidation. I would use it on track at any point, but not longer than 3-5k.
Which begs the question why would Blackstone tell him to increase his mileage instead of decrease it?
On the Redline site it’s 11.9 it’s peaked to 12.5, need to cut down the interval. Still, I want to try this oil for fun. Thanks for the UOA.
