It came up when I plugged my car into their product finder, and they said it would work in an email I received.Where did they make this claim? I have read their OEM compatibility list and CHF11S isn't on there.
Yeah, it seems like an error. I’ll be doing the power steering at some point. I’ll just do a fluid change at first and see how it look. I’ll either use Pentosin CHF 11s or I might try the Liqui Moly Central Hydraulic Fluid, since it lists it as suitable.I believe their site is incorrect. I just plugged in the info for my 2009 328i, which also requires CHF-11S, and it came up with two recommendations that aren't compatible. One is their D4 ATF (listed under power steering) and the other is their power steering fluid. If you look at the OEM compatibility tab under their power steering fluid it states:
"RED LINE POWER STEERING FLUID satisfies the service fill requirements of most auto manufacturers and can be used where the manufacturer calls for any automatic transmission fluid such as Dexron®, Dexron II®, II-E®, or Dexron III®, Ford Type-F, Mercon or M2C138-CJ such as required by Ford, AMC, Toyota, Nissan, Lexus, Infiniti, Jaguar, VW, Mercedes-Benz, BMW, SAAB, Subaru, Volvo, Porsche, Mitsubishi, Mazda and many others."
So I believe it isn't the correct fluid and can only assume they don't make something compatible. I'd just stick with the CHF-11S and don't forget the BMW reservoir has a filter, so that whole reservoir can be changed out fairly cheaply/easily if the fluid is really nasty.
I've used both the Pentosin and the Febi with good results.Yeah, it seems like an error. I’ll be doing the power steering at some point. I’ll just do a fluid change at first and see how it look. I’ll either use Pentosin CHF 11s or I might try the Liqui Moly Central Hydraulic Fluid, since it lists it as suitable.
How much fluid is required to change the power steering fluid? Did you just suck it out of reservoir ?I've used both the Pentosin and the Febi with good results.
I'd say one can of the Pentosin is good for 2 drain and fills of the reservoir. I just used a fluid pump to drain the reservoir fluid, turn the wheels back and forth, and did that a few times.How much fluid is required to change the power steering fluid? Did you just suck it out of reservoir ?
