Originally posted by Patman:
[I think that's why so many 10w30 synthetics still exist. It's not like they are necessary, it's just that a lot of people continue to run them out of habit. But nowadays a good 5w30 synthetic is just as good as a 10w30 in hot weather, but it's better than the 10w30 in cold weather, so it's truly the better choice.
Well, this raises an interesting question, because some 10w30's seem superior (at least to this old cowboy), than their 5w30 counterparts:
Example 1: Mobil 1 10w30 has a higher flash point than Mobil 1 5w30 (471.2 to 435.2) and a higher HT/HS rate (3.17 to 3.08). Both have identical pour points (minus 45 degrees)
Example 2: Syntec 10w30 compared to 5w30, also has a similar trend (flash points of 450 to 435 and HT/HS of 3.1 to 2.92). Similar pour points of minus 36 to minus 39 degrees.
Both of these oils, regardless of viscosity, meet the GM 6094M standard, which I understand is low temp pumpability.
Conversely, some oils seem much closer, such as 5w30 Redline to it's 10w30 counterpart. Kendall GT-1 synthetic is also very close between these viscosities (flash points of 455 to 446, and HT/HS of 3.2 to 3.1). Pour points are identical (minus 39 degrees).
The above info taken from published specs/company web sites. I have some published cold cranking viscosities for Castrol and Kendall but not Mobil 1. However, these figures are for minus 25 (10w) and minus 30 (5w) degrees.
So if the ambient temp is way above that (like in Calif.) does the 10w30 win out because of what appears to be better wear protection (for some oils)
So, this is why I think some people still want to run 10w30. I dunno, I am still confused...
Bob W.
