This is the 3rd and what will likely be the final run UOA testing Red Line on my 2004 S60 in which I switched up somewhat running 0W30 for the winter months as opposed to their 5W30 grade as in the previous 2 runs. As I have mentioned in my last post, this car is long paid off and I prefer to spend my money on an product made by a small US company, but comments are of course welcome with that in mind.
Links to Previous UOAs:
Red Line 5W30 - 1st Run
Red Line 5W30 - 2nd Run
There was trace fuel found in this sample, but I believe this to be related to an ignition coil failure at approximately 3,000 miles into the run, the car went into a limp mode and I was able to drive it to my independent Volvo mechanic where I had all five coil packs replaced.
Generally speaking, I am ok with the UOA on the 0W30 grade from Red Line, but the 5W30 produced better fuel economy and a quieter engine. I have moved back to 5W30 for the current fill and noticed an approximate 1 MPG average increase in economy through 2 fillups. Based on this I plan to run 5W30 for the foreseeable future and will continue to change it at ~10k mile intervals with the Volvo OEM filters (Mahle).
BLACKSTONE COMMENTS: The only mark on this report was for a slightly low flashpoint reading, indicating a trace of fuel was present. That's not an excessive amount of fuel, so we doubt it's anything to be concerned about. If fuel had been a lingering issue or if it had read much higher (over 2.0% of the sample), then we'd be singing a different tune. For now, this reading is fine though. Wear metals look pretty good. Iron is a little higher than it has been, but it's not excessive at all. The TBN read just 0.1, but we can't say this low reading is hurting anything.
Code:
OIL Red Line 0W30
MILES IN USE 10,925
MILES 147,068
SAMPLE TAKEN 04/19/2014
MAKE UP OIL 1 QT
ALUMINUM 1
CHROMIUM 0
IRON 21
COPPER 2
LEAD 1
TIN 0
MOLYBDENUM 668
NICKEL 0
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 1
BORON 37
SILICON 9
SODIUM 19
CALCIUM 2759
MAGNESIUM 48
PHOSPHORUS 1240
ZINC 1362
BARIUM 0
INSOLUBLES % 0.2
FUEL % TR
WATER % 0
ANTIFREEZE % 0
FLASHPOINT ºF 385
SUS VIS 210ºF 60.4
cSt @ 210ºF 10.33
TBN 0.1
Below is a photo of the car:
Code:
OIL Red Line 0W30
MILES IN USE 10,925
MILES 147,068
MAKE UP OIL 1 QT
ALUMINUM 1
CHROMIUM 0
IRON 21
COPPER 2
LEAD 1
TIN 0
MOLYBDENUM 668
NICKEL 0
MANGANESE 0
SILVER 0
TITANIUM 0
POTASSIUM 1
BORON 37
SILICON 9
SODIUM 19
CALCIUM 2759
MAGNESIUM 48
PHOSPHORUS 1240
ZINC 1362
BARIUM 0
INSOLUBLES % 0.2
FUEL % TR
WATER % 0
ANTIFREEZE % 0
FLASHPOINT ºF 385
SUS VIS 210ºF 60.4
cSt @ 210ºF 10.33
TBN 0.1
