red from the dip stick
Southern Ontario
I had noticed this in the past but remembered to snap a pic today. The red smearsseem to be coming off of the rubber washers found at the top stick (09 GM 3.6L DI)
I wonder if this would be evident in a UOA, maybe as...red dye #7?
Originally Posted By: tom slick
assembly lube for the o-rings.
It for for sure does come off of the inside of the o-rings...'trapped' against the dipstick.
Originally Posted By: Bluestream
This is way automobiles are refered to as "She's"...
LOL!!!
I would change that oil and filter - just because red doesn't naturally belong on an oil dipstick. Probably won' hurt anything leaving it in -- but changing the oil and filter is just something I would do in that same circumstance/situation.
I had seen this early on after taking delivery of this vehicle but thought nothing of it but by coincidence I have also done two very short UOAs in the past 6 weeks..interested in the break in #s. See here:
http://www.bobistheoilguy.com/forums/ubb...939#Post1494939
