No, the stuff that gets "rerefined" gets turned into expensive fleet use motor oil.quote:
Does it get turned back into cheap "store brand" motor oil or what?
quote:
Originally posted by Gary Allan:
[QB]No, the stuff that gets "rerefined" gets turned into expensive fleet use motor oil.Does it get turned back into cheap "store brand" motor oil or what?
Who uses these fine and expensive products?? .![]()
The US Military make a lot of noise about recycled oil that meets MIL-PRF2104G for their combat and tactical ground vehicles, basically high quality HDEO.
LOL, on the morning parody show on the radio they were referring to Britney's wedding plans.quote:
Originally posted by TC:
According to the tabloids, most old oil is used by Britney Spears and Christina Aguilara in their various sexual escapades. I have no reason to doubt them.
The bulk of it winds up in heating oil.quote:
Originally posted by Hirev:
What do they do with all that used up recycled oil? With millions of gallons out there they have to use it on something don't they? Does it get turned back into cheap "store brand" motor oil or what?
Thanks for the reply. If it's good enough for you guys it would be great for the truck at work. I'd love to see a VOA on this stuff.quote:
Originally posted by farrarfan1:
TN I am not a guru but my department (Indiana State Police) uses Americas Choice 5W30 in our CVPI's. Seems to work just fine. My 2001 that was retired from duty in July had 107,000 miles on the clock. OCI's are 5k. It used about 1/2 quart in 5k and that was always in the last 1,000 miles or so.It must have done a good job over 3 years. We've used this oil for many years. The 55 gallon drums it comes in shows SL GF-3 rating.
If I didn't know better I'd swear you're obsessed with Britney and Christina and their "sexual escapades"quote:
2% Britney & Christina sexual escapades
http://www.recycleoil.org/Usedoilflow.htm
Down here in Doo-Dah land we use it for the same purpose.quote:
Up here it is used to heat shops. They use waste oil burners.
So you have a mixture of 0, 5, 10, 20, 30, 40, and who knows what else just like in crude oil. First step is to boil it away capturing different fractions that boil in a narrow range. The lower molecular weight stuff comes off first (gasoline, diesel, water), and then each higher range. Most of the additives will stay behind along with sludge and wear metals. You may have to measure the VI to know how much VII to add to hit any given range. Maybe just sell each fraction as what ever it measures. Sort of like melting down a batch of scrap and letting the lab decide what grade of brass it is or what to add.quote:
Originally posted by ekpolk:
Not that I'm actually tempted to use the stuff, but I am curious about one thing: how does the "re-refiner" control the viscosity of its product? The used oil would seem to be a witches brew of multiple different vis grades, spiced up with ATF, gear lube, and other substances one would not expect to see in a healthy motor oil.
