Toyo4by4,
You have a mechanical problem here, so using a heavier oil is simply a bandaid. I suppose it's possible this engine is severly worn, but you'd really have to abuse a toyota engine to wear it out in 120k miles. I'd swear it's taken 60k for my tacoma to fully wear in the engine.
I'd also look at the crankcase vent system and make sure you aren't getting blowby that is pressurizing the crankcase. Check the bottom of the engine carefully for leaks as well.
If it turns out the engine is simply worn, then I'd run a 10w-40 synthetic like Redline or Amsoil. That should reduce your oil consumption by 50%-70% ....If you want to stick with Mobil, I'd recommend Delvac 1, 5w-40 over Mobil 1, 0w-40. D1 is thicker and more shear stable and it also evaporates less at high temps.
TS
TS
