Quote:
But same price or little cost more, dont recomment me wix pls. I want filter the flow and performing better the motorcraft filter, have better anti-drain back valve or equal
With all those limitations( price being tops), it seems as though you should stick with the Motorcraft. I'm not sure which app you are referring but the FL820-S has thread end bypass and silicone adbv, good features. Drawback is it's rated 80% efficient.
As mentioned, Puro Classic is more efficient at 97.5% with nitril adbv and dome end bypass, but would be close in price. IMO, the bypass location is not a big deal.
Motorcraft filters do seem to work well in Ford products. With normal OCI's up to 5k they should be ok.
EDIT: I like Pure One also, but depending on MC app, it will be more expensive.
