Hello BITOG folks. Been lurking here for a bit now, gleaning HEAPS of valuable information, and recognizing some faces from the various Impala SS boards. Guess it's time to register and post up!
Car in question is a '95 Impala SS, pushing 90k miles, and driven under less-than-kind conditions frequently. The car's been to the dragstrip a few times, with more frequent visits coming. I see WOT at least once daily, frequently more often. The engine (LT1) revs higher than it would in stock form due to higher stall torque converter and 3.73 rear gear ratio. (stock is 3.08) It's also deceptively dirty around here in Western MA now that the snow is melted and the street sweepers remain comatose.
I got the car at 64k and switched over to M1 5W30 - performed two 3K mi oil/filter changes. I've learned a bit since then and extended my OCI to 5K with M1 10W30. I use the Ultraguard Gold ACDelco oil filter with each change.
I've recently found M1 0W40 locally and just filled up with it. I'd like to do an analysis of this oil, as it seems to give quieter startup and high-rpm operation than the 10W30 - it seems that this is what I'll be sticking with (contingent on UOA.. hopefully it will correlate with my rudimentary criteria.
) for a while, and I'd like to find an ideal OCI. $4.98/qt is a little pricey IMO, and if I can get away comfortably with >5K changes, I'd be perfectly happy to do so!
So the question is... What would be the recommended first time to send a sample in for UOA? I was planning on 4,500 miles just in case I'll only get 5K due to conditions/etc.. Any other comments/thoughts on the oil/filter combination I'm running?
Thanks!
Thanks!
