My new Toyota Tacoma (V6) should be delivered within the next few weeks.
What brand or type of "break-in" oil is "best"?
Which oil has a high level of moly?
What oil change interval would you recommend during the break in?
Thanks for you input!!
quote:I'd recommed using the factory fill oil until the factory recommended first oil change. The factory fill sometimes is a special blend designed for break-in. If the first recommended oil change is at 1,000 miles, I'd use any decent dino-juice and switch to synthetic at the second oil change. It the first recommended oil change is at 3,000 miles or more, then I'd switch to synthetic at the first oil change.
Originally posted by mulepacker: My new Toyota Tacoma (V6) should be delivered within the next few weeks. What brand or type of "break-in" oil is "best"? Which oil has a high level of moly? What oil change interval would you recommend during the break in? Thanks for you input!!
