Recomended Oil for Diff and Transfer Case
Alberta, Canada
1995 Chevy 3/4 ton 4x4 I`m in Canada so it gets down to -38'C here and already use PP syn for the engine but would like to change Diff`s and Tansfer case to Synthetic oil. Recommendations would be appreciated.
NH
Royal Purple MaxGear for the diff's( in the appropriate weights - use 75W-90 in place of 80W-90 if called for ). I would assume your t-cse would call for Dex ATF so Royal Purple MaxTF there.
NH
Redline is a very good brand. Their gear oils and ATF's are some of the best out there. They are pretty much my 2nd choice for fluids other than oil behind RP. If it is more readily available to you than the RP it is an excellent company with great fluids. It is more $$$ than RP however and harder to come by for me anyway.
Phoenix, AZ
 Originally Posted By: tig1
M1 gear oil works well in cold temps. Are you confused yet?
I bet he's confused! All oils mentioned in this thread will serve you well.
TN USA
I have a 94 k1500 14 bolt rear end 9.5" ring and pinion gear and have the same question. I can get a pretty good deal at Summit racing on the 75W 90 Synthetic. Does anyone have experience with this oil?
TN USA
Also do I need to put an additive in the fluid for the limited slip differential? It is a 14 bolt semi floater with 9.5 " ring gear.
